Yamaha YST-SW800
Discussion in 'Home Cinema Speakers' started by n0chex, Jan 12, 2004.
  1. n0chex
    n0chex
    Oct 31, 2003
    7,535
    Here on AVF
    +384
    Yamaha YST-SW800 basically i wanted to know how this performs has anyone had a demo of it .
    it is going cheap at the moment £349 ,looks good on paper the spec etc any further details will be appreciated .
  2. n0chex
    n0chex
    Oct 31, 2003
    7,535
    Here on AVF
    +384
  3. mw3cdj
    mw3cdj
    Nov 12, 2002
    399
    West Wales
    I got one of these for about a year now, and found it v. good. But i have spent a lot of time setting it up with a BFD and also noticed that it sounds tighter and more controled since i placed it on a marble slab.
    Regards ,
    Daran
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    It's one of their better subs but be wary of the specs - their quoted frequency range uses a -10dB reading which makes the sub look like it goes a lot deeper compared to competitors who generally use -3dB. So, whereas they quote 18Hz, if you applied a more realistic -3dB this would probably rise to 25-30Hz.
    Something they also used to do was quote output power with a ridiculously high THD reading thereby making the amp look a lot more powerful than it really is. In other words 800 watts may not be as powerful as it sounds.
    Matt.
  5. n0chex
    n0chex
    Oct 31, 2003
    7,535
    Here on AVF
    +384
    So is there a sub out there at around that price what will beat its performance.
    i had a yamaha yst 305 6 months ago dual 8" Drivers and personally i thought it was crap ,well i sat crap turn the volume up and loads of chuffing and distortion.
    Im looking for a subwoofer that can be felt as well as heard if that makes any sense.
    A mate had a Rel strata Mk 1 which i borrowed and i liked that very much apart from it popping at high volumes it was connected with the XLR maybe i had it set wrong and expected too much from a 60w sub ,if anyone can Recommend a sub please do so i don`t really have a price range but as all of us we all like a Bargain :)
  6. stegalv
    stegalv
    Dec 16, 2003
    866
    +35
    im having the same touble,want to upgrade from a 305 thought mine was faulty till i read your thread looks like they are crap,know what you mean about feeling as well as hearing same as i have been asking on other forums,decided to try and build my own, lower cost for higher spec,just trying to understand all the ins and outs
  7. n0chex
    n0chex
    Oct 31, 2003
    7,535
    Here on AVF
    +384
    Keep us updated mate which ever way you go.
    I think maplins do a full panel for the purpose of building your own subwoofer.
    There must be a subwoofer on the market at a reasonable cost that makes you think to yourself now thats what im after,ive been doing alot of review reading on the net in the last week or so
    I would have liked to try the Servo 15 but they are like rocking horse s**t .
    Ive even looked at a second hand M & K 500 ......Im very undecided at the moment which one to go for .
    Thx for looking at my thread
  8. stegalv
    stegalv
    Dec 16, 2003
    866
    +35
    iplacoustics.co.uk are selling a sub which looks the business but it is in kit form for around £307, they claim it will match any £800 sub, on their home page click on audax reference units,then scroll down to sw3, i assume it will be better than the yam 800 but do you take a chance without hearing it,maybe someone has heard one,this is my problem about building one, spending my money and it being no better than what i have.let us know what you think of it
