Yamaha YST-MSW10 SUB and Sony STR1080 Will It Work
Discussion in 'Subwoofers' started by malford, Jan 11, 2004.
  1. malford
    malford
    Jan 13, 2003
    261
    Camberley, Surrey Heath
    +28
    Hello,
    I have a Yamaha yst-msw10 subwoofer that used to go with my PC setup, the question is will it work ok with my Sony STR1080 amp?
    I have no problems hooking it up with the amp but Im worried that i might fry the speaker if i go above 39db.
    Product Description Yamaha YST MSW10 - speaker(s)
    Device Type Speaker(s)
    Dimensions (WxDxH) 20.1 cm x 25.9 cm x 27.9 cm
    Weight 5.5 kg
    Enclosure Colour White
    Audio Output 1 x subwoofer - 16 cm
    Audio Amplifier Integrated
    Response Bandwidth 35 - 250 Hz
    Signal-To-Noise Ratio 98 dB
    Output Power / Total 25 Watt
    Power Power supply - integrated
    Manufacturer Warranty 3 years warranty
    I only want to try it because my wife doesnt like it on the PC desktop anymore and thought it might go under the sofa and give me a mean bass pump up my ar*e, joking aside any help would be appreciated.
    Regards Malcolm
  2. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    How is the sub connected to the amp?
    What other speakers are you using?
    I don't think you will fry it if its connected via a phono connection but i don't think it will be up to much in a av system.
