Yamaha YSP-5600 Atmos not working
Discussion in 'Soundbars, Soundplates & Soundbases' started by MadMaelstrom, Dec 8, 2017.
    1. MadMaelstrom
      MadMaelstrom
      Feb 10, 2005
      1,819
      +164
      I've just done the firmware upgrade to 4.01 and noticed that when I now go into the audio information menu its only showing TruHD now - previously it did differentiate between that and Atmos. Tried with both my Oppo and Nvidia Shield (both with Atmos sources) and nothing - it definitely worked before, any ideas anyone?
    2. Clem_Dye
      Clem_Dye
      May 8, 2006
      3,529
      +535
      Do a factory reset perhaps. If that fails talk to Yamaha.
      Clem
    3. MadMaelstrom
      MadMaelstrom
      Feb 10, 2005
      1,819
      +164
      Did the trick, thanks
    4. Rick84
      Rick84
      Feb 16, 2013
      2,430
      116
      Doncaster
      +570
      How are you finding the 5600?
      Im considering selling my AV kit and having 1 of these. Do you get genuinely bubble effect ?
    5. achild
      achild
      Jul 14, 2006
      47
      How do you do a factory reset? Thanks
    6. Clem_Dye
      Clem_Dye
      May 8, 2006
      3,529
      +535
      I have the older YSP-4100, same form factor, and have been very pleased with it. I'd certainly consider a 5600 when/if the occasion arises. The only gripe that I believe that I've seen is that there's no HDMI passthru when the bar is in standby. My 4100 has that feature, and I rely on it, so no not have it would be a bit of a PITA.
      Clem
