Yamaha YSP-500 Remote Handset Keeps Blinking
Discussion in 'Soundbars, Soundplates & Soundbases' started by sunnshinesdad, Oct 27, 2017.
  1. sunnshinesdad
    sunnshinesdad
    Mar 1, 2016
    4
    France
    Advice appreciated. I have the YSP-500 Soundbar with the WK 86950 remote.
    Recently, the red light on the remote has started to blink continuously.
    Very annoying for my boss (wife) during the night!
    I renewed batteries, but problem remains. I thought a sticking button, but can't see anything suspicious.
    Blinking stops when I move right hand YSP/TV slider to TV?
    Anyone had similar issue?
    D
  2. JayCee
    JayCee
    Jan 20, 2004
    23,898
    Lanarkshire
    +2,593
    If an led on any remote is “blinking” on it's own that suggests a remote command is being transmitted.
    The usual cause is a sticking button or moisture between the buttons and the rubber membrane/circuit board.
    You'd need to take the remote apart to check.
  3. sunnshinesdad
    sunnshinesdad
    Mar 1, 2016
    4
    France
    Thanks Jaycee - will do
    D
  4. sunnshinesdad
    sunnshinesdad
    Mar 1, 2016
    4
    France
    Thanks guys! It eventually stopped completely, dead!
    So as you suggested I took it apart and cleaned everything with a tissue soaked in Bushmill's Irish whiskey, and it now works perfectly!
    (Of course Yamah told me it was not a repairable item, and I could buy a new one for £50 or so!)
