Yamaha YSP-30D & YSP40D Discussion Thread
Discussion in 'AV Receivers & Amplifiers' started by onkeh, Sep 5, 2007.
Tags:
  1. Floob
    Floob
    Sep 1, 2003
    364
    +22
    I have the YSP-1100, and what seems weird is that the PS3 seems to support more audio systems (dts, Dolby etc.. ) when using optical than using HDMI - you can see this when you select the audio out in the menu on the PS3.
    I have PS3 (HDMI) TV (Optical Out) YSP-1100
    But I listen to sound via PS3 (Optical Out) YSP-1100
  2. STEVENM1000
    STEVENM1000
    Mar 16, 2008
    130
    +6
    As I do not want the hassle of a 5.1 system with rear speakers/cable sorting I have been looking at sound bars and 2.1 systems.
    From the few reviews available the Yamaha ones appear to be the best.
    Does anyone own one or listened to one as I do not want to spend the equivalent of a decent 5.1 system if all you get is glorified stereo.
    I appreciate they will never be as good as a decent 5.1 but if they are say 80% as good I would accept that to avoid the rear speakers issue.
  3. Floob
    Floob
    Sep 1, 2003
    364
    +22
    I'm happy with mine, but best results are made from using the manual settings. They have just brought out a new HDMI based model, shorter at 61cm but probably still a good performer.
    Have you read the YSP-1100 review?
    http://www.yamaha-uk.com/pdf/YSP1100 What Hifi Jan 07 5 star41.pdf
    There are a lot of settings, and I'm still playing around with mine.
  4. STEVENM1000
    STEVENM1000
    Mar 16, 2008
    130
    +6
    Thanks Floob - I do want HDMI capability as intend getting a blue ray player and Sky HD if the price ever comes down.
    Would you say you do get some surround effect then and not just the simulated poor quality effect you get with TV's.Not many places seem to sell the sound bars, could this be due to the relatively high cost compared to 5.1 systems or the quality of the sound?
  5. louisg
    louisg
    Jun 11, 2005
    2,470
    Leicester
    +72
    i have a ysp 800 and the effect is very pleasing in the right shaped room.
    I would reccomended them and i will one day uopgrade to a 1100 or hopefully a 40D
    Louis
  6. Subversion
    Subversion
    So is there a definitive answer on the multichannel PCM over HDMI question? Does either the 30D or 40D support it?
  7. Black-Adder
    Black-Adder
    Nov 25, 2005
    465
    Peoples Republic of Yorkshire
    +32
    According to our chums on the AVS Forums it's seems that multichannel pcm over HDMI isn't supported by the YSP:thumbsdow
    http://www.avsforum.com/avs-vb/archive/index.php/t-928552.html
    I may try a optical cable but so much for investing in a 1.3 special hdmi cable where it's all supposed to go down the same "pipe".
    Still love the YSP though...very pleasing.
    PeBe :hiya:
  8. Black-Adder
    Black-Adder
    Nov 25, 2005
    465
    +32
    I highly recommend you go to a local retailer and ask them for a demo (the yamaha website provides a list of local dealers). We had our demo in a square room, where the walls were littered with other bits of kit. The sound effects in this 'imperfect' listening environment were superb (I even checked the wiring just to make sure there was no real speakers behind us).
    The impression I had was the sound did seem like it bounced off the walls to your ears and whilst it didn't quite seem like having a speaker behind you I can't think of anyone who has forward and backward facing ears. To me it seems more natural to hear the sounds coming from the front and sides.
    Bit of a ramble i know but it's always subjective to the room layout, how clean your ears are, what the visual and audio source is, etc.
    It's well worth the cash layout and now it's plugged into the PS3 I find my Harmon Kardon speakers are collecting dust...
  9. don.juan
    don.juan
    Jun 3, 2008
    With Firmware 2.30 for PS3, the following is available:
    "Today, SCEA announced that the latest PS3 update, 2.30, would bring the ability to decode DTS-HD Master Audio and DTS-HD High Resolution Audio tracks, that is to say, Blu-ray audio at variable bit rates up to 24.5Mbps, and 7.1 streaming of 96K/24-bit tracks. Does this make PS3 the best Blu-ray player ever? If you've got a receiver that can take an uncompressed audio stream of that magnitude via HDMI, then we think it does. UPDATE: To be clear, this decodes the DTS formats—plus Dolby's formats, including Dolby TrueHD—and outputs all channels via HDMI to a receiver that can take a 5.1 or 7.1 PCM stream. It won't do 5.1 or 7.1 analog output. Also, as some of you have noted, it does NOT bitstream the DTS or Dolby data to a decoder inside a newer decoder-equipped receiver."
    I'm I safe to believe that with a PS3 running firmware Version 2.30 connected to the YSP-4000 (YSP-D40) via HDMI that if I could get LPCM 5.1 on the YSP-4000 (YSP-D40)?
  10. don.juan
    don.juan
    Jun 3, 2008
    Please browse to this site...Yamaha states that it is not possible to update an existing HDMI interface to a different specification.
    http://hotline.yamaha-online.de/index.php?action=artikel&cat=11&id=43&artlang=de
    Using Google Translate this is what I get:
    Can a HDMI interface update?
    An update (better upgrade) of an existing HDMI interface or the subsequent installation is not possible.
    This is not only a new software necessary but it is an adaptation of the hardware.
    Among the versions of the HDMI interface some details:
    Which version which supports sound formats?
    * HDMI 1.0: PCM, Dolby Digital, DTS, MPEG
    * HDMI 1.1: in addition DVD-Audio
    * HDMI 1.2: additional SA-CD
    * HDMI 1.3: in addition Dolby Digital Plus, Dolby TrueHD, DTS-HD
    What is the difference in the video?
    * HDMI 1.3: greater bandwidth, Deep Colour, high signal solutions (1080p), new color standard xvYCC
    Which version is supported?
    Basically you will find the words to the version used in the technical data of related equipment.
    Are the versions?
    The versions are backward
    Last update: 2008-04-01 13:01
    Author: YAMAHA Hotline".
  11. msephton
    msephton
    Jul 9, 2002
    757
    Cornwall, UK
    +54
    Two new Yamaha sound bars have been released, both around £500
    YSP-600
    http://www.yamaha-uk.com/sound_projectors/?product_id=211
    HTY-760
    http://www.yamaha-uk.com/sound_projectors/?product_id=212
  12. don.juan
    don.juan
    Jun 3, 2008
    Q. Do I need v1.3 HDMI to hear the new Dolby TrueHD and DTS Master HD audio content on HD-DVD or Blu-ray players?
    No. The Dolby TrueHD, Dolby Digital Plus, and DTS-HD Master Audio can be decoded by the playback device into multi-channel Pulse Code Modulation (PCM) digital audio streams, which is an audio format standard that can be sent over any version of HDMI. In fact, all versions of HDMI can support up to 8 channels of PCM audio at 192kHz, 24 bits per sample.
    To do this, consumers should ensure that their playback device (such as HD-DVD or Blu-ray player) is capable of decoding these new lossless Dolby & DTS audio formats into the PCM format on the HDMI output, and that the audio device (such as an A/V receiver) is capable of receiving multi-channel PCM audio over the HDMI inputs. Consult your user manual/product specification sheet to determine whether your device supports such PCM capabilities (we believe that nearly all HD-DVD and Blu-ray players will, but users should confirm this). Devices that support HDMI v1.3 and higher may also offer the option to transport the high definition audio formats as a compressed, encoded stream over HDMI so that the decoding function can be performed by the A/V receiver (whereas the above transport method has the playback device performing the decoding).
    PLEASE, WILL SOMEONE CONFIRM THAT THIS IS THE CASE WITH THE YSP-4000 AND PALYSTATION 3 USING FIRMWARE 2.30 (or higher)?
    I do not see a reason, now that PS3 is able to decode DTS-HD, for it not to work with the YSP-4000!!!
  13. don.juan
    don.juan
    Jun 3, 2008
    I've been sending e-mails to Yamaha using this link:
    http://www.yamaha-service.de/index.php?lang=e
    Just pick your country (and some others...I've sent to Portugal - my country, Germany and Great Britain) and ask about LPCM 5.1 over HDMI...maybe if enough of us complain we will get an answer...
  14. Pete
    Pete
    Oct 13, 2002
    62
    Emailed Yamaha UK re the 5.1 over PCM and got the following reply, today. No mention of firmware upgrade, unfortunately :(
    Thanks for the email
    Yes you are correct the YSP will default to a 2ch pcm audio signal when it
    receives HD audio, sorry.
    With any blu-ray disc you can select from the discs own menu to select
    other audio options (ie 5.1)
    Many thanks
    Steve
    Product specialist
  15. don.juan
    don.juan
    Jun 3, 2008
    Well, I thing that does it for me...I will not be buying the YSP-4000!
  16. scaper
    scaper
    May 14, 2007
    170
    London
    +7
    I think the ysp 600 and the hty 760 are the same, just different colours. Has anyone seen a review/own one ?
  17. scaper
    scaper
    May 14, 2007
    170
    London
    +7
    bump
  18. don.juan
    don.juan
    Jun 3, 2008
    Don't ask me how (use the web) but I got in touch with the chap at South Africa that had the firmware upgraded for the YSP-4000.
    This is what he wrote me:
    Hi Paulo,
    Apologies about the delay, your email was sent to the SPAM folder by mistake.
    Please note that you cannot install the firmware upgrade on your own (as specialist equipment is needed). For more information on the firmware upgrade, I'd suggest you contact the South African distributors of Yamaha products, at the following
    Website: http://www.balancedaudio.co.za/contact.php
    Physical Address:
    Balanced Audio
    82 Lechwe street
    Sage Corporate Business Park South
    Midrand
    South Africa
    Postal Address:
    Balanced Audio
    Postnet Suite 195
    Private Bag X4
    Bedfordview
    South Africa
    2008
    Tel +27 11 314 0760
    Fax +27 11 314 0764
    Email: [email protected]
    Good luck,
    Muneer Natha
    I Encourage you guys to contact the South African distributors of Yamaha products!
    I will be sending a Fax asking for information regarding the firmware upgrade.
  19. robin1989
    robin1989
    Mar 6, 2008
    68
    11
    Warrington
    +4
    hey im looking at getting a yamaha sound bar as i have a rectangular room with blins so its perfect for bouncing sound. im considering the 40d.
    i have a ps3, wii, hdmi dvd player, skyhd and the regular tv and currently its all plugged into the tv and was wondering if i could use the digital optical audio out on my tv to take all the sound from my systems and send it to the yamaha.
    also i was wondering if you guys could tell me the difference between the 40d and the usa 4000 apart from the xm radio/dab radio difference.
    also is this price to good to be true
    http://lookangoo.com/product_info.p...=5651&osCsid=8828a145afdfa05a482da722f433ea73
    thanks for helping a new person at surround sound or semi surrond as my parents have said i can get it as long as there arnt trailing wires all over the room
  20. rosswf
    rosswf
    Sep 23, 2005
    36
    Woking
  21. don.juan
    don.juan
    Jun 3, 2008
  22. rosswf
    rosswf
    Sep 23, 2005
    36
    Woking
    Thanks don.juan. Could I instead connect the HD-DVD player via optical and get 5.1 that way? Just seems utterly crazy I cannot achieve surround sound using an HD-DVD player and this box somehow.... :confused:
  23. don.juan
    don.juan
    Jun 3, 2008
    Via optical it works, but you get DD5.1, no DTS-HD.
  24. rosswf
    rosswf
    Sep 23, 2005
    36
    Woking
    OK, many thanks for the info. At least that's something - though why Yamaha did not include this on the spec is quite beyond me - annoying :mad:
  25. kevinf123
    kevinf123
    Hi - I'm new to this thread and hoping someone may be able to help. I have a YSP-40D with SKY HD and Apple TV working fine through the HDMI inputs. I'm trying to get a DVD player working through my component inputs (AUX2) but cannot get this to work whatever I try.
    According to the manual the YSP should upscale the component video through the HDMI link. I've tried this with several devices, made sure the upscaling settings are set right but cannot get it to work. Does anyone else have a device connected through the AUX2 component input and upscaling successfully?
    Any suggestions appreciated !
  26. devilhunter
    devilhunter
    Jan 1, 2008
    36
    Kent
    I am now ready to purchase a soundbar and wanted things clarified first.
    My set up is the following -
    52" LCD TV - 3 hdmi, 2 scarts etc etc
    Virgin Media cable - hdmi
    dvd player - hdmi
    ps3 / xbox 360 - hdmi
    VCR - scart
    Laserdisc - composite L/R audio into scart.
    Now how can that lot be connected to a 40D ?
    Can I not leave the connections as they are in the tv but just take the sound from the invidual components into the 40D or since the tv has both digital audio out and RCA L/R audio out connect just the audio to the 40 D this way ?
    The cable box, dvd, ps3 and laser disc all have digital sound outputs although the dvd is the most important for surround then its the ps3 then cable (happy with standard 2 channel sound for everday watching) and finally the laserdisc.
    I cant see why I need take the video signal though the 40D aswell ?
    Please shed a little light guys.
  27. gzcunnin
    gzcunnin
    Nov 18, 2008
    I'd appreciate advice regarding which product to purchase; 30d, 40d or 600, 900, 1100.
    I have a Panasonic 42" PX70, DVD Recorder XBoX 360 and am in the process of upgrading to Sky HD. The room is appox 17 feet square.
    Usage is mostly by the childen however we will use for DVD, and Sky.
    Given the big price differences would the smaller boxes be sufficient or, given the screen / room size am I looking at the 40d v 1100? With all the discussions on HDMI I'm inclined to go for the 1100....
    alternatively I could go for a 30d for £50 more!
    Advice / help much appreciated for a novice.
  28. louisg
    louisg
    Jun 11, 2005
    2,470
    Leicester
    +72
    go for the 1100. my set up is similar to yours. i currently have a 800 and will upgrade to a 1100, you could always buy my 800 though :smashin:
  29. djphineart
    djphineart
    Hello I am not sure if this is the right place to ask but Here goes. I have had the YSP1100 in a second home and was so pleased with it I decided to go for the YSP 40d with additional sub for my main home set-up.
    I am teaming it up with a Samsung 63" inch 1080p plasma and the following sources so need to know if the connections I have planned will work:-
    1) Sony PS3 - HDMI into the DVD HDMI on the YSP with the
    2) Sky+ HD box - HDMI into the YSP STB HDMI
    3) Nintendo Wii - Component video into DVD/Aux2? Audio into ??? got confused at this point
    I was sold on the idea of the up-scaling of the YSP doing a job on the WII's fun but lame graphics but now I am looking on the rear panel I cannot see how this works as the two HDMI inputs I have already used will surely conflict with the component video inputs labelled STB and DVD/Aux2???
    I also wanted to be able to plug my MP3 player into the soundbar via the aux 1 RCA inputs (its not an ipod so I don't want the dock). Have I got this horribly wrong as I really wanted to put all four sources into the YSP but am beginning to think it only does two?
    I need to know as I am about to start sinking cables into the wall and I am confused.
    Any help much appreciated :lease:
  30. jelly_belly78
    jelly_belly78
    Nov 26, 2008
    12
    I have the old YSP-1100 because I'm renting and can't hang speakers on the walls or chase out the plaster and I think it's pretty good. If you don't need HDMI just yet I'd go for one of these old models.
    In my setup I have a 42" Panasonic plasma, with the YSP mounted below, and a Sony sub, PS3 for Blu-ray replay and it sounds mint for Blackhawk Down and associated war film sounds.
    I run the PS3 to the telly using HDMI and then from the audio out on the telly two phono leads to the YSP. It has a 5 beam and 3 beam setting and the auto setup is pretty good. Plus it's completely configurable in the settings department. In all not bad for a small house or where you need a compact setup.
