Yamaha YSP 1000
Discussion in 'Home Cinema Speakers' started by daddyp, Aug 28, 2006.
  1. daddyp
    daddyp
    I'm in the process of sourcing some kit for my Uncle and just have a few questions.
    They've decided to go for the yamaha ysp1000 because they don't want speakers everywhere! but from what I can gather people using the ysp800 have all said that you need a sub. Is that the case with the 1000?
    If so I'll have to start looking for one to go with it. It'll need to be fairly unobtrusive as looks do play a major part in their decisions. They aren't audiophiles or tech minded, they're just doing an extension and want a good setup. I get dragged into the decision making process because I enjoy researching these types of things, but I've become a bit stuck with this one.
    It'll be partnered with a panasonic 42lx600 that will be wall mounted. If that helps.
    Daddyp
  2. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
    I'd say you (and you're uncle) have to listen to the YSP before you buy a sub, it has reasonable low range as standard, it's not a true sub-like rumble but definitely worth checking out first.
  3. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
    of course if they're in the process of building/installing, for the sake of a £5 cable, make sure they get it grouted along with the other cables.
  4. daddyp
    daddyp
    Thanks for that. We're basically going to put all the cables in, such as HDMI etc that he's likely to need and stow them away. He is big into war films and Lord of the rings, so he might well want to go for one, but we'll definatly have to source one for a demo
