Yamaha YSP-1 connecting DVD/SKY etc...
Discussion in 'Home Cinema Speakers' started by Sulis, Apr 13, 2005.
  1. Sulis
    Sulis
    Mar 29, 2004
    575
    Bath
    I'm very tempted by the YSP-1, wall mounted under a plasma, to avoid wires/obtrusive speakers (I just tried a friend's 5.1 speakers - AAD - very small, but still changed the feel of the room unbearably). But I'm a bit confused how I might connect all the DVD/SKY/PS2/Video boxes to it without getting into Wire Hell again.
    Is there a simple, minimum cable way of connecting all these boxes and still have them about 8 feet away in the corner? And possibly having the sub in the corner, too?
    Ta very much.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,240
    The Borders
    +2,940
    Hello Sulis
    A few questions:
    Which DVD player?
    SKY or SKY+?
    What cable kit with your PS2?
    Best regards
    Joe
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,616
    Bristol.
    +309
  4. Sulis
    Sulis
    Mar 29, 2004
    575
    Bath
    Thanks, Cap'n. Looking at the User Guide from the Yammy site, it does look as though having DVD/PS2/Video etc. some distance from the YSP-1 and the plasma screen is going to involve vast amounts of cabling.
    All the video signals have to go to the plasma separately, while all the audio has to go to separate inputs on the YSP-1, then 2 cables have to go from the YSP-1 to the plasma as well.
    How irritating.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,240
    The Borders
    +2,940
    Hello Sulis
    Not necessarily so - I'd need answers to the earlier questions though before we can give you a definitive answer :)
    Best regards
    Joe
  6. Sulis
    Sulis
    Mar 29, 2004
    575
    Bath
    Sorry, Joe -
    DVD player: Not bought yet, but was going to start with the Panny DMR-EH50 DVD/HD for general use, archiving SKY+. Might add a better DVD player for dedicated viewing if it seems worth it - general opinion is that HDMI players don't add that much except to the Pios.
    SKY: SKY+ (upgraded to 160Gb)
    Plasma: Panny 500HD (prob 37") - not bought yet, obviously
    PS2: Not sure what connection it is, the 3 phono plug one... (this is not a big deal)
    Crappy old video recorder for crappy old kid's stuff and a very worn out copy of Midnight Run...
    And of course I'd like to connect my Mac PowerBook (or Mac mini, maybe) to at at some stage as well...
    Hope that answers your questions... THanks.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,240
    The Borders
    +2,940
    Hello Sulis
    My 'choice' of DVD Recorder may be out-with your intended budget - so you may want to look for lower cost alternatives; I've suggested what I know/supply.
    I trust this makes sense :)
    DVD Recorder Pioneer DVR-920 (DVDR)- will require a unit with HDMI or DVI + Digital Audio Out.
    PS2 - will require 1 x RGB SCART cable kit.
    Mac Mini - will require 1 x Stereo Audio to Digital audio (optical) adapter.
    Digital Video + Audio switcher - will require 1 x Gefen EXT-HDMI-241A (see http://www.gefen.com/kvm/product.jsp?prod_id=2590)
    PlasmaTV/Display - will require a unit with HDMI or DVI Digital Video Input.
    Connectivity:
    PS2 - SCART RGB+LR Audio to SKY+.
    SKY+ - SCART RGB+LR Audio to DVDR
    VCR - SCART to DVDR
    DVDR - HDMI + Optical audio to Gefen switcher.
    Mac Min - DVI + Optical audio* to Gefen switcher.
    (*Using Stereo to Optical adapter)
    Gefen switcher - HDMI (Video) to PlasmaTV (or Display) + Optical Audio to YSP-1.
    Cables:
    You will require 1 x 8m HDMI + 1 x 8m Optical audio between the Gefen switcher and your YSP-1/TV.
    You'll use the DVDR as your video hub and only have to switch the Gefen switcher as and when you want the Mac on-screen.
    The sub will require a separate cable from the Sub out on the YSP-1.
    Best regards
    Joe
    PS The YSP-1 works well with a 42" Display - we've even done a couple on mobile 'trolley' stands for 'mobile' 5:1; there are three user definable set-ups in the YSP-1 so you can move it from room to room with ease.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    sulis not meaning to ask a stupid question?
    but the Plasma you are considering has built in speakers already and if the room is small and wont take a regualr small 5.1 system is having 2 speakers in the plasma and then a YSP1 underneath a bit odd? the YSP1 is very good but not sure it is the ideal partner for a PV500.....
  9. Sulis
    Sulis
    Mar 29, 2004
    575
    Bath
    Thanks, Joe - that's about as comprehensive an answer as you could ask for! Looks like there are some advantages to HDMI... :)
    HD - it's not a stupid question. We've been borrowing a spare 5.1 system from a friend. It's not even wired up yet, but Er Indoors has decided she doesn't like 'having all these speakers looking at me'. It's not a tiny room (19' x 15'), but because it's got a lot of old features even these small sats really stand out.
    I'm definitely interested in the new HD Vieras, as I can't wait until September for a G8 panel. I know they have built-in speakers, which is fine for CeeBeebies, the News, etc., but if the YSP-1 is the only way to get 5.1-ish sound, then I'd better look into it!
    I'm assuming that there's no way to get a reasonable 5.1 sound using the built-in speakers and a couple of rears...?
    Another option would be the Onkyo CB-SP1200, don't know if it'll be in the UK at all...
  10. alanrowell
    alanrowell
    Dec 14, 2004
    81
    +7
