Yamaha YAS-108 will not accept DTS, Dolby, or even LPCM input from PS4
KBD
I finally got my soundbar working with my LG CX TV & then I remembered I had set the PS4 to funnel DTS to the CX, which it will convert to Dolby Stereo, or at least that's what the soundbar reports (Dolby Pro Logic II).
So I thought, easy-peasy, I'll just run audio through the optical, but alas, I cannot get it the soundbar to report anything other than Dolby Pro Logic II from the PS4, this is after manipulating it through LPCM, DTS, Dolby, & trying 3 sources, Tubi-TV (PCM), Wrath of Khan (Dolby) & Fight Club (DTS).
Here is the indicators sheet:
Only #2 lights up, EVERY time!
unless I set it to stereo or 3D surround & then nothing lights up
With the Sony UBP-X700:
Khan = white HDMI
Fight Club = red HDMI
Tubi = none = PCM
I tried routing LPCM & Dolby through the CX TV from the PS4, but that had the same results.
Bakey
Is this because you’ve connected with an optical cable and not a hdmi? Sorry if this isn’t the case, I used to have a Yamaha YAS-107 and could only get all audio options if using hdmi, they weren’t possible using optical.
KBD
That might be the case, but I was sure that my YAS-101 was getting DTS from the PS4.
It's gone now however, so I can't put it back on there & see if I was correct.
If I can't get it to do DTS or Dolby, I suppose I'll just run it through ARC from the TV in LPCM.
I just found this in the 108 owner's manual:
goose0211
thanks, no optical cable but possibly its not actually an issue.
Seems, from reading online that the DTS light may not light up on this device when playing a disc with DTS - perhaps any 207 owners can confirm if this is the case - cant find anything to direclt confirm this.
KBD
DTS fires up red when playing from my Sony UBP-X700.
but that's only a direct HDMI 2.1 connection, there's no optical out on the X700
