Question Yamaha Yas 107 set up
Discussion in 'Soundbars, Soundplates & Soundbases' started by Dutster, Feb 25, 2018.
  1. Dutster
    Dutster
    Feb 25, 2018
    Prestatyn
    Help wanted , new to this it's my first post
    I have just purchased the 107 and having problems setting up the dts virtual x (light not turning blue)
    I have a hdmi from br player to 107 hdmi in and hdmi (arc) to tv
    I'm getting dts ( red light ) but not sure what I need to get virtual x
    My TV doesn't have (arc) is this the reason
    I'm getting Dolby through my optical cable
    Hope I'm making sense
  2. Dutster
    Dutster
    Feb 25, 2018
    Prestatyn
    Anyone help ?
  3. Bakey
    Bakey
    Jul 14, 2015
    353
    96
    UK
    +918
    Have you downloaded the virtual x update from the Yamaha website? I had to do that to get it to work.
  4. orac1971
    orac1971
    Jun 21, 2007
    2,077
    +166
    Yes what they said. Mine had virtual x on the box, so already has the firmware update.
    You press surround twice to get the blue light or select 3d surround on the app
  5. Dutster
    Dutster
    Feb 25, 2018
    Prestatyn
    Sorted it thanks for your help
