Yamaha volume
Discussion in 'AV Receivers & Amplifiers' started by mooky, Sep 9, 2003.
Tags:
  1. mooky
    mooky
    Those of you who own a Yamaha Receiver or are familiar with them could maybe answer this question.
    Having come from a hifi enironment in to HT i'm now getting to grips with a myriad of different things such as "reference level", the need to calibrate my speakers at 75Db, sub settings etc.
    I understand the concept of 00Db as reference and calibrating a system for 75Db however my question is this. In my old hifi world I went by the mantra that you shouldn't really run your amplifier over half way, and in fact never needed to as it was perfectly loud enought below this. I now have moved to HT and live in a world of DB's and reference levels. The question is, although I understand that the DB reading on my AMP is relative my amp *ALSO* has a bar graph on the front of it, which does give some resemblance to a normal volume dial with a min and max. So, where on this bar graph does the 00Db lie ? At the max, in the middle or somewhere else ? And if this bar graph means anything, does the same old adage apply that I shouldn't run the amp past half way on it, regardless of the Db ?
    Thanks for you help,
    Mark.
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    If I remeber rightly my Yammy ax620 started at -75 db and went up to +14db with reference levels being 00 db. I generally never went past about -30db before it became too loud. 00db must be deafening. I think I''m right in saying it's on a logarithmic scale so the volume increase from -75db to say -50db is less than -50db to -25db.
    Hope this helps a bit.
  3. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    i would second that, ive not even got close to reference with mine.
