I just added Sonance MAG6R speakers (mounted in the ceiling about 2' in front of listening area) to use as ATMOS speakers. The rest of the speakers are Speakercraft AIM, main L &R speakers in the wall, center and surrounds (which are ceiling mounted with surrounds about 2' behind listening area and center directly above the TV and are about 8 years old and still sound good (to me). This is in a family room with a lot of windows and doors, hence using walls for mounting. The terminals I used for the ATMOS speakers are called front presence. The surround terminals used are called surrounds (the rear surrounds terminals are not connected). From consulting the manual, this seems to me what is called for. The TV and receiver are connected by a new high speed HDMI cable and the TV is used to go online (Netflix, Apple, internet, and cable). The YMAO was used to set up the speakers and the measurements did come out correct, and the adjustments automatically made are from 0 to -1db. Listening to the test sounds, they all sound like they did before adding the ATMOS speakers,
I do not have a ATMOS BD player and can't seem to find a way to play any test ATMOS files (assuming You Tube plays stereo only and any other on line files I found induce a message "action not supported"), so my only chance to play any ATMOS media is by buying a movie online - so I bought Star Wars Last Jedi. The movie says it is in DOLBY ATMOS and HDR, and playing it seems to be in HDR but does not indicate it is ATMOS although I do see 7 speaker boxes lit up on the Yamaha panel. I have tried going through the menus on the Yamaha and have not made any difference except that straight will put it in stereo mode. I see from other posts that Yamaha does indicate Dolby ATMOS when that is what is playing.
To be honest, I think I liked the 5.1 sound better than what I am getting now - everything seems kind of non directional where before I did hear left to right sound and to a small extent front to back as well, and definietely rear background sound. Now everything seems to be coming from in front and above all at once if that makes any sense. Any ideas what I have done incorrectly? Or maybe I messed up because the speakers are not specifically ATMOS? The proverbial guy at Best Buy recommended these speakers as good ones to use for adding ATMOS - but I bought them ;-(
