Yamaha TSR 5810 Sub Out no signal
tdsd
Hi, I have a Yamaha TSR 5810 Receiver. The amp on my power sub failed so I purchased a Dayton stand alone amp. I get a loud thump when I turn it on so I think it is working. I get no sound from my subwoofer. I have the setting in configuration for the sub as "Use" Crossover 80hz, Subwoofer Phase "Normal" Extra Bass "On". I get no signal when use the YPAO setup. It seemed to work OK when the sub amp was working OK. How can I check to see if there is a signal coming from the sub out on the receiver? I only have one subwoofer. I changed cables with no change. Thanks in advance
