yamaha sub
Discussion in 'Subwoofers' started by JFK, Apr 6, 2002.
  1. JFK
    JFK
    Apr 6, 2002
    227
    middlands of no return
    +14
    Hi All, I've got a yamaha ax620 amp, and in the manual, if u set speakers to small, frequences from 90hz and below are sent to the sub. I also have a yamaha sw45 sub, B&W 302 s and cc3, for which the cc3 goes down to 80hz and the 302 s goes to 72hz. What do I set my high cut at on the sub? At 90 to match the amp or between 70 & 80 to match the speakers. No need to worry about rears as they are Ariston MSX03 MKii from richer sounds at £15. cheers.
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Set the subs crossover (high cut) to maximum as the amp will be controlling the cutoff i.e 90hz. If you dont like the sound then lower the crossover until the sound is to your liking.
