Yamaha Sub YSTSW315
Discussion in 'Subwoofers' started by JoeyJoeJoe, Oct 22, 2003.
  1. JoeyJoeJoe
    JoeyJoeJoe
    I've seen this sub on hifistore.co.uk's website for only £220. It seems to have a similar spec to the BK XLS 200. Does anyone have or had the YSTSW315? How good is it? This sub is just about within my budget but I don't want to buy a lemon. Other than the BK, can you recommend any other sub at no more than £250?
    Cheers.
  2. Lister
    Lister
    May 15, 2003
    70
    11
    London
    just bought YSTSW320 FRO £200, from www.hispek.com.
    Not tested it yet, but for that price your not going to get anything better.
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    not sure what the competition is, but the yamaha hasn't received very good reviews...maybe worth checking out for some second hand stuff.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    A spec can be confusing and invariably tells you very little. If you are referring to the frequency response they are invariably meaningless and if you are referring to the size of the driver and amplifier it is again a meaningless statistic as the quality of the driver and amp itself is so important but cannot be quantified.
    Having said that, I agree with babble that keeping an eye on the classified forum here is the best way to get the maximum sound for your pound with the BK being the obvious choice if you insist on buying new.
  5. JoeyJoeJoe
    JoeyJoeJoe
    I was just wondering what I could get for the £250 mark. There appears to be quite a waiting list now for the BK so I may be swayed towards picking up a SH one in the classifieds.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Try putting a wanted ad in the classifieds and see what turns up
  7. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Hey Joe.
    I bought the exact same sub. from HifiStore also.
    I am very satisfied with the sub. however it hasn't got good reviews from anywhere really but it does fit in with my system well, so i'm fully satisfied.
  8. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Yamaha are notorious for their over optimistic specs. For the SW315 they claim RMS output of 250 watts and a frequency response of 20-160Hz. Looks very impressive until you read the small print.
    That 250 watt RMS output is at 100Hz and (get this) with 10% THD!!! I think the normal "fidelity firewall" is 0.5% THD. In other words, the 250 watts is with a ridiculous amount of amplifier distortion.
    Then there's the frequency response. 20Hz but it's at MINUS TEN dB! And you thought REL were taking the p*ss quoting +/-6dB figures. Realistically, I wouldn't expect much below 30Hz.
    Matt.
