akroblade954
Can anybody help with the above? Need to know what fuse rating to put in the 3 pin plug having taken delivery of my 757 from Europe.
akroblade954 said:Can anybody help with the above? Need to know what fuse rating to put in the 3 pin plug having taken delivery of my 757 from Europe.
akroblade954 said:Thanks for that. I have a 5 amp - do you think that will be too high??
What I may do is put the 5 in and run it gently until I can get confirmation then change to a 3 if necessary.
Does that sound (half!!) sensible to you??
Badger0-0 said:That'll be fine, IMO, I really wouldn't worry about it too much.
5 will be ok.
