Yamaha - RXV683 - Won't turn on
joejoeinc
I have a Yamaha rx-v693 amp that won't turn on It'll click twice and then turn off.
I have tried the factory reset. (init all)
Self diagnosis C1 Menu is showing this.
C1-1
all:NG
C1-2
Invalid
C1-3
Bus_from:NG
C1-4
Bus_Fpgn:NG
C1-5
I2c:1-1111-0ng
C1-6
Dir B:eek:k,ok
C1-7
DSP B:ng,ng
C1-8
EEProm: OK
C1-9
Invalid
C1-10
I2c2: -- 1:ng
C1-11
Inavlid
c1-12
CEC Chk:ng
I suspect the main CPU is fried but would like some advice.
Joe Fernand
AVForums Sponsor
'I suspect the main CPU is fried but would like some advice' - contact your Supplier, the local Yamaha Service Centre or an independent Service Centre who have access to Yamaha parts and service manuals.
Joe
joejoeinc
I suspect the same, I tested the power supply last night and the power looks fine. I think I'll take it in soon and have a professional look at it.
jas6004
Sounds like same problem i have fixed before on 2 Yamaha Receivers, a capacitor on power supply circuit board fails. A cheap and reasonably simple fix.
Check the link below for plenty of info.
Hope this helps.
Yamaha RXV1700 - Power Problem
