Question Yamaha rxv677
Jpleeco
I have this amp and everything I put through it works brilliant. You name it Xbox, Humax, Minux, Wii. Apart from one thing. A blue ray player?
Every time I put a blue ray on the creek just goes black with obviously no picture or sound.
If I connect the blue ray to the tv it's fine?
Any ideas why? Is the amp faulty?
fxv300
Does the blu ray player work directly connected to the TV ?
Bear in mind copyright protection HDCP2.2
Describe your blu ray device please.
dante01
Why would HDCP 2.2 have anything to do with anything? No Blu-ray title is as yet protected by it and this will be the case until there are UHD BD players and UHD discs to play on them. Current Blu-ray standards do noe use or encompass HDCP 2.2.
I can only suggest the OP try a different HDMI cable between the player and his receiver.
