Quantcast
Yamaha rxv630rds and B&W Speakers
D
Dan110
Will this amp comfortably drive B&W 602s3 front, LCR600 centre and 3x600s3 rears or should I be looking at something with a bit more power to get the best out these speakers? If so any suggestions?
Dan
bash
They'll power them, but I personally recommend a higer grade amp. Sony 333 or similar price bracket........
D
Dan110
Can anyone else pitch it with some advice, I really need to order something in the next couple of days.
G
Geoffc10
yes i agree, B+W need quite a beefy amp, Id go for something like the KEF cresta range, or maybe take a trip down to richer sounds.Maybe Mission or Eltx range. You want speaker around the 89/90db (8ohms)
planbeta
Isn't the 602 around the 89/90db (8ohms)?
T
Tejpal
That reciever should be fine, a clean 75 watt per channel(which it does) is more than enough. Unless you will be using them at over "rock concert" levels, then you should worry.
I am using the B&W 602 S3 in a stereo combo with the Nad C370(min 120w), and the things still crave more power!
I wouldnt listen to the advise about the Kef Cresta, they are in a whole different league altogether!
Geoffc10 would it really be wise to swop B&W for Eltax?:confused:
At the end of the day, if you can afford to spend more, get a better receiver, but I think that the Yamaha will do just fine.
I noticed a subwoofer wasnt in the speakers listed, I would recommend you get a beefy one. The B&Ws dont go very low.
MuFu
Really?! I'd be very suprised if you are reaching the limits of that amp with 602 s3's.
MuFu.
G
Geoffc10
i read the post wrong, i thought he was buying new speakers to go with the yammy.
D
Dan110
Thanks for the response guys, just to clarify, already have the speakers and i'm out to buy a sub and receiver this week. Looking at the CHT10 for the sub and still deciding on the receiver. Will a Marantz 6300 do a better job than the yammy 630rds or should I stick with the yamaha?
Thanks again,
Dan
planbeta
The marantz 6300 has 25 watts more power so this may be usefull, suppose the best way would be to get a demo!
ISHANTY
try to get a demo on both then make your mind up i chose my system on what i liked and what i would be using it mainly for
my set-up
SKY+ PACE
DSP-630 SE
B&W 602 S3 FRONTS
B&W 600 CENTRE
B&W 602 S3 REAR
ASW 3OO SUB RAN OUT OF MONEY BUT ITS STILL GOOD
PHILIPS CD-CDR RECORDER 775 WILL BE CHANGING TO YAMMY CDR 120G CD RECORDER
Similar threads
