Yamaha RXV596 crap?
Discussion in 'AV Receivers & Amplifiers' started by majak, Feb 18, 2003.
Tags:
  1. majak
    majak
    In the process of buying a receiver have my mind set on the Yammy 630, but because I bought a more expensive speakers than planned I'd like to buy a cheaper receiver.
    Talked to a salesman he told me that I definety should go for the 630 for my Kef Q5/Q9c/eggs. (They do sell other brands, thats what he recomended and it sounde great).
    So my question is will the old 596 match this sound, I know that I won't get DPLII, what else will I miss.
    I plan to get hold of a cheap one and than upgrade after a while when my girlfriend (and I) has forgotten the speaker cost :)
    Any opinions for a go/no go are welcome.
    P.S. I can stretch my budget to the 630... D.S.
    Regards
    Tomas
  2. majak
    majak
    Another question how old is the model? A link to a spec would also be appreciated, havn't been able to find one...
    //Tomas
