Yamaha rxv540 and Tannoy FX5.1
Discussion in 'AV Receivers & Amplifiers' started by First-Timer, Jul 26, 2004.
Tags:
  1. First-Timer
    First-Timer
    I am looking for a home cinema amp/receiver and a set of speakers for under £500. I can pick this pair up for approx £380 which seems pretty good (Amp £220, speakers £160). Will these work well together? Would I be better going for the Mordaunt Short Premiere Plus speaker set?
    Will this also be any good for music as well as movies?
    Any advice gratefully received!!
  2. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    welcome to the forums!, I have a yammy rxv740 which i am using with the tannoys at the moment ( upgrading time :D ) which sounds awesome with movies but with music it is all down to your taste in music , I quite like the sound from the tannoys in multi channel mode but they can seem a little harsh , so I prefer to use my kef q50s for stereo, and most of all dont forget the amp is primarily for movies. hope this helps.
