Yamaha RXV1400 or RXV1500 ???
Discussion in 'AV Receivers & Amplifiers' started by wes2008, Nov 20, 2004.
Tags:
  1. wes2008
    wes2008
    Hi guys,
    Can some please advise what is the different between these 2 model in terms of features and quality? RXV1500 appears to be the replacement of Yamaha RXV1400, but the retail price in Australia has dropped, so I was wondering is it because Yamaha RXV1500 has compromised in features or any way?
    Please advise which one should I go for? :lease: Know any matching DVD player for these AV receiver?
    Many thanks...
    Cheers,
    Wes
  2. askegg
    askegg
    The 1500 is the replacement for the 1400. On paper there is not much between them (except the price), but according to this store the 1500 sounds much better.
    I would recommend the Denon 3910. Check this site for great info on DVD players.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,501
    London
    +995
    The 3910's comparator is more like the Yamaha 2500 rather than the 1500.
    As askegg said there is very little difference between the 1400 and 1500, the main thing is a bit more more power.
