  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Yamaha RXV1400 No Signal
Discussion in 'AV Receivers & Amplifiers' started by betamac, Dec 9, 2004.
Tags:
  1. betamac
    betamac
    Hi i have my Sky + and DVD player plugged into my 1400 via Component and then the AMP is plugged into my plasma via Component,
    Everythign was working fine until today when i changed the Hifi Stand i have put everything back and plugged it all in but now on SKY and DVD sources every few mins the Plasma loses the signal (just says no signal) now i know its not the plasma as i have the Gamecube plugged into plasma via component and its perfect
    So its either the AMP or the Cable, i dont see why it would be the AMP considering it was fine this morning when i unplugged
    So is cable likely problem? or anything else which could be causing it?
    Thanks in advance
  2. bbasra
    bbasra
    Sep 15, 2004
    1,600
    48
    Hounslow
    +34
    why dont you try plugging the dvd player and sky box directly into the plasma, that way you can test the Dvd player, sky box and their cables, if all is well, then you know that problem lies with the amp or the cable from the amp into the plasma.
  3. betamac
    betamac
    Hi m8
    Right i did what you said and no problems atall with lost signal when DVD player in plugged directly in Plasma
    Now that means its the AMP but what could of possibly happened moving it from one place to anouther? as it worked fine previous it was not dropped or knocked or anything.
    Only other thing is power i have everything thing plugged into a 10 way extension before it was a 4 way would that cause a problem? if it was a power prob surely the display on the AMP would flicker off? it dosn't though
  4. betamac
    betamac
    Just tried plugging AMP into a different socket on its own and still happens so not power
    Now i am stumped.
  5. Fishbones
    Fishbones
    Jan 26, 2004
    126
    Madeira
    Hi betamac.
    Do you have OSD from AMP via component to Plasma?
    I also have no signal from AMP to Plasma via component, not even OSD. I suspect the cable, but before taking everything apart, I would first like to confirm if it has anything to do with the settings.
  6. betamac
    betamac
    Before i moved to AMP from 1 stand to anouther everything worked fine i had OSD no problems SKY and DVDs were perfect no loss of signal atall
    After the move if i select OSD then it says no signal and wont display it if i choose SKY or DVD it looses signal every few mins for a few seconds extremely annoying, or in DVDs when your browsing the menus everytime the menu changes it goes no signal then comes back again.
    The sound stays constant so its defo the video switching side of things, i have already eliminated cable problems by plugging the cable from plasma into DVD player and it works perfect no problems so defo not cable, surely it must be something simple as i only moved the damm thing lol
