Yamaha RXV1400 Banana plugs?
Discussion in 'AV Receivers & Amplifiers' started by woody123, Dec 9, 2003.
Tags:
  1. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    I thought you could use the plugs with this model but looking at the back they seem not to be accepted.
    Is there a way around this please - it would be a nice to have but no biggie if its not possible.
    Good old Yamaha!
  2. Steve Rollings
    Steve Rollings
    You can use banana plugs on RX1400, just push the plug thru the end of the speaker terminal on the back of the amp. I have done this on mine and it works fine, although initially I thought the same as you and Yamaha had done it again (I had an A1 before)
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Page 12 of the manual - ignore what it says about uk models being excluded
  4. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,076
    38
    +6
    It's true you know. :)
    Just use a sharp object to take off the middle cover part of where the plugs are.
    That kind of makes no sense, but, meh.
