Yamaha rxv-550 VS. rxv-640
Discussion in 'AV Receivers & Amplifiers' started by Byte, May 19, 2004.
Tags:
  1. Byte
    Byte
    Jan 13, 2004
    15
    Lahti, Finland
    I found that actually rx-v550 seems better than the "old" rx-v640. Only preouts are missing (which I don't need). So is rx-v550 a good choice? Does anyone know if the insides are identical to rx-v650? And the sound quality is as good also?
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    On paper the RX-V550 is a better buy for the money but I tend to prefer the sound of the 640 - more of a weight behind it. Still, I would advise getting a chance to listen to both.
    Markie Boy
