Yamaha RXV 495 and DTS/Dolby Digital
Discussion in 'AV Receivers & Amplifiers' started by -, May 14, 2001.
Tags:
  1. Guest
    Steve
    Have you checked the Sony menu system to check that the digital out is not restricted to PCM?
  2. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    ermmmm, no i haven't
    I suppose that is in the audio settings menu. Would that also be the reason that the DTS logo does not illuminate when DTS is selected on Gladiator? The other thing is that the X Men disc illuminates the Dolby Digital logo but the amp still displays Pro Logic......or am i wittering now?? (you canm tell i'm upset about it can't you!) ;)
  3. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    Steve,
    In the DVD players audio menu, select output 'bitstream'. The amp should now automatically setect DD/DTS.
  4. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    I just realised, it's a Yamaha RX-V496RDS, not 495....DOH, maybe if i put in the correct info it may be easier for you all....I'll have a play tonight on that one Nike
    Cheers All, hoping for 5:1 til the early hours!
  5. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    This may be in the wrong forumn but i'll give it a go anyway.
    I have a Yamaha RXV 495 coupled with a Sony DVP 335, both of which have DTS and Dolby Digital symbols on the display. I'm sure the amp has a decoder for both DTS and DD but i just can not seem to get this working. I'm using a digital lead to transfer the audio. When i put in the Gladiator disc and select the DTS soundtrack it just reverts to the normal pro logic setting and X men displays Dolby Digital on the DVD display but the amp just Pro Logic. This is driving me mad as i SHUOLD be able to decode both of the required formats. Can someone help me?? :confused:
  6. Guest
    Welcome aboard. Prepare (possibly)
    for a narcotic like addiction to
    take hold.
    Regards
    SteveEX
    And he just stand's there waiting
    for me to drive my truck straight
    through him..... with light coming
    out of his mouth!!!
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The unit has DD/DTS decoding, that's for sure.
    Try using a different (digital) input after checking your DVD players setup (bitstream must be enabled for DD/DTS) - if no success.
    As well check if the auto-decoding is set to "on", else try to switch manually to DD/DTS.
  8. Stewart C
    Stewart C
    The Yamaha has an auto format select, similar to Sony amps and a manual select. Check that it is set up as automatic or it will not 'see' DD/DTS.
    Regards :)
  9. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Thanks Guys, with your help and a chat with Techtronics re: RCE i've got everything working now, DTS, Dolby Digital, Charlies Angels (R1), the whole shebang......
    I feel like i've just had my system delivered again, that DTS is utterly superb.
    What Joy!
    Cheers again
    Steve ;)
