Yamaha RXV 2500 Quick Question
Discussion in 'AV Receivers & Amplifiers' started by betamac, Jan 17, 2005.
Tags:
  1. betamac
    betamac
    Anyone know why my Yamaha 2500 seems to of lost my Surround Speakers
    When i goto Manual set the surround speakers are set to NONE and i cant change them
    It was working when i first bought it as i set it to 2 X Small
    On AUTO setup it plays the test sounds through the 2 surround rear channels so that shows there connected fine
    But as there turned off in manual Setup i assume that means they are not gona be used
    Thanks in advance
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Are you sure your not getting confused with rear back?
    As a 5.1 should have the rears plugged into rear left and right and not rear back left and right.
    Otherwise check connection?
  3. betamac
    betamac
    Hi m8 no i have a 7.1 Setup and its defo the Rear Surrounds which are set to None
    And as AUTO setup says the connections to the rear Surrounds are working fine i am pretty sure there connected fine
    Its just Manual setup wont let me select anything other than none
  4. teabag1605
    teabag1605
    Do you have the presence speakes on, as the rears can not be turned on when the presence speakers are enabled.
    Regards
    teabag
  5. betamac
    betamac
    Presence also set to NONE
    not sure whats happened as i know i enabled them on manual setup when i first got the AMP
    very odd
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    When you do the automatic setup you remember to save it?
  7. betamac
    betamac
    Yep after i did AUTO setup i made a few changes in manual setup and saved
    Do you reckon it will of saved the rear surround settings and it wont matter if the Manual setup says NONE?
    I guess the only way to tell is get a 6.1 DVD and try it
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Run the autosetup again save the settings, maybe the factory set was without surrounds and you didn't save the autosetup. Thats the only thing i can think.
