Yamaha rxv-2500 component video
Discussion in 'AV Receivers & Amplifiers' started by AlanA, Mar 2, 2005.
Tags:
  1. AlanA
    AlanA
    As i am very new to this could someone please advise wether I would be better to connecting my dvd player through the amp component video or going straight to the tv component video
    Thanks Alan
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The theory says that a direct connection is better. I would choose that unless you have more sources than inputs at the TV or you "need" it out of convenience.
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    I think any signal loss you would recieve through going via the reciever would be negligable and would probably not be noticable on a CRT. You could always check to see if you can notice the difference.
  4. Beastie Boy
    Beastie Boy
    Remember also that the monitor output of the amp needs to be connected to a display in order to see set-up menus etc. For convenience, I would connect via the amp, any future devices then may be connected to the amp inputs enabling the amp to be used for component switching. This would also allow you to use the component upscaling feature of this amp, thus minimising the number of cables.
    Congratulations on choosing a great amp BTW :)
    Cheers, Beastie.
  5. AlanA
    AlanA
    Hi Folks thanks for the input very helpful
    Regards Alan
  6. ehayde
    ehayde
    Sep 21, 2004
    4
    Chippenham
    I use my yammy as my video hub - ie all audio and video passes thru it. I have no problems whatsoever with the pic quality
    regards
    EJH
  7. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    ehayde, i tried to do the same with my yam 2400 but i can't seem to get it to output a picture to my plasma :confused: any ideas what i'm doing wrong? cheers for any help.
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Have you turned viseo up conversion on?
  9. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I'm sure i did but will check again later ;)
  10. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Only just got around to trying it out and all seems fine and dandy now :) thanks for your help though
  11. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    864
    London
    +29
    Does the RX-V1500 also have component upscaling?
  12. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    The 1500 and 2500 are pretty much the same, so yes it does.
  13. alanfcross
    alanfcross
    Don't confuse 'up-scaling' with 'up-conversion'. The first is pixel and line resampling (possibly accompanied by conversion), the second is simply interface standard conversion with no resampling. These amps, AFAIK, do conversion, not scaling.
  14. rb10
    rb10
    hi
    sorry to hijack the thread but:
    i've also got this amp along with a pio 505xde, a panny S97 & a E95 dvdr/hdd.
    just wanted to ask:
    1) at the moment the yammy-2500 is connected via component to the plasma. the S97 via hdmi to the plasma and the e95 via component and optical cable to the amp via the DVD component input. however, as stupid as this sounds, will I need to connect the aerial to the e95 inorder to be able to record i've got the aerial going to the plasma right now. At the moment i cant get any picture or sound on input 2 on plasma (and using component switching on the amp) i.e. cannot get the dvd tuner to "tune" so to speak so I can view the tv channels.
    2) the s97 is connected via hdmi to the plasma, however, as speakers/sub are connected to the amp and the only connection between amp and plasma is component cabling, there is no sound unless i connect the s97 via optical to the amp. but there is only one DVD optical input on the amp and so i can use it for either the S97 or E95. can i use any of the other inputs such as CD, DTV, etc?? what changes will i need to make to the settings if so.
    thanks in advance
    :thumbsup:
