Question Yamaha RXA2020
Discussion in 'Home Cinema Buying & Building' started by agganesh, Jun 16, 2015.
  1. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
  2. jk330ci
    jk330ci
    Sep 12, 2010
    1,184
    63
    Wales
    +127
    They have been around for a while, remember their adds being in the back of what hifi years back.
    Iv never dealt with them but would imagine they would be ok.
  3. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,393
    +1,303
    It was never that much as it was the second from top of range which normally retailed for £1499 but you could pick it up fairly cheap when the newer models came up.
    Having said that it if it ticks all the boxes for you it would be a good buy.
    It probably won't pass Full 4K signals being 2 generations behind the latest model if that is important going forward.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,917
    The Borders
    +3,569
    Other than the Price and 3D (assuming that is a requirement) what else do you require out of a new AVR!
    Joe
  5. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
    Since I had posted I found some negative feedbacks on trustpilot so I am bit concerned.
  6. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
    Good point. I haven't thought about it but 4k is not my priority now. I have 7 years HD ready plasma screen and latest Sony 3D projector.
  7. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
    Twin HDMI out, pre outs for all channels, power output equivalent to 2065 (but I got bryston to power fronts, surrounds are small speakers so not sure If I really needed)
  8. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,393
    +1,303
    I do wonder if its the same shop as that's .com and the one you link to is .co.uk.
    Also some refer to car stuff which it doesn't look to do.
    Purchase on your Credit card and that will give you better protection.
  9. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
    Ouch! How did I miss it?
    The .com site doesn't seem to be working so there is no way we can confirm. Probably I'm going to bite the bullet and pay by card after doing little more research.
  10. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,393
    +1,303
  11. agganesh
    agganesh
    Aug 27, 2010
    1,643
    48
    Manchester
    +75
    That was a smart job. Thanks.
