Yamaha rx673 sub test signal
Discussion in 'AV Receivers & Amplifiers' started by lollski, Feb 24, 2013.
Tags:
  1. lollski
    lollski
    Feb 24, 2013
    2
    Hi anyone have ideas to try and solve my issue. I had set my amp up and all was workin fine then sub stopped working. I then tried going back in to the menu and put out a test signal,the amp is not producing a test tone for the sub.
    Please help
  2. dante01
    dante01
    Mar 5, 2009
    45,870
    +10,964
    What make of sub do you have. Does the sub have an auto power feature, if so then turn this off so that the sub never goes into standby?
    In the speaker configuration settings, ensure that the SUBWOOFER setting says NORMAL, thus indicating to the receiver that a sub is connected and being used.
  3. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    How do you know the amp is not outputting to the sub and that it is not a problem with the sub itself?
  4. Michael
    Michael
    Jun 7, 2009
    2,538
    Truro
    +186
    Unless you are using fullrange speakers too, in which case I apologise; is the amp set to send low frequency L/R/C etc to the sub?
    And is the sub enabled on the system? I know that my (admittedly older) Yamaha allows the sub to be disabled altogether.
  5. lollski
    lollski
    Feb 24, 2013
    2
    Hi Gents,
    Many thanks for your replies, all sorted now. I switched all the speaker settings to small and its all good.
