Yamaha RX2500
Discussion in 'AV Receivers & Amplifiers' started by Damnyoureyes, Nov 24, 2004.
Tags:
  1. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    Now this seems to be trickling into our shores, anybody know if there are any differences between German models and the UK ones.
    Seems to be the same model numbers.
    Also places to buy 789 quid on digital direct seems to be cheapest over here compared to something like 630 in Germany technikdirect.
    With regards to the power supply could I just change the plug over to get it to work with our mains or would I need a converter (ie does the internal power convertor accept before voltages.
    Steve
  2. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
  3. recruit
    recruit
    Have you tried emailing Yamaha as from the Lack of response it does not look as if anyone knows! :(
    John
  4. teabag1605
    teabag1605
    Wih regards to the power, there is no difference all you will need to do is change the plug.
    regards
    teabag
  5. wes2008
    wes2008
    I asked a similar question about a week ago before I purchased my RXV-1500. I didn't get any response, maybe there not many people have them yet. Yes, it is true that Yamaha has decided to drop their retail price world wide with the replaced model. I found a site that compare the features of RXV-2400 and RXV-2500. I hope this web site can help you.
    http://www.audioholics.com/cedia/cedia2004/yamahaRX-V2500receiver.php
    I have enjoyed my RXV-1500 for a week now, and love it.
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    There was a tread on this called buying a 750SE from germany. I contacted yamaha uk and there are no difference and the warranty is covered. The GUI is even in english.
  7. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    Thank you folks :D
