Yamaha RX-V740RDS handset programming
Discussion in 'AV Receivers & Amplifiers' started by tmurphy, Jul 8, 2003.
Tags:
  1. tmurphy
    tmurphy
    Mar 5, 2003
    621
    Preston
    +93
    I have had the above amp now for 1 week and amVERY pleased with it.
    However! DOes anybody know if it can be programmed to operate a Grundig Digi box? I've gor it controlling the Plasma and DVD, but it would be nice to get all equipment working in one handset.
    Tony
  2. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Hi again,
    I got my goodmans digi box working by setting the one of the spare button (ABC) to L:SAT and Manufaturer code Philips5. I did however scroll through each of the codes to find it which you may also have to try. I bet there is one for your digi box somewhere. It still only controls the basics ie power on/off and channel selection.
