dante01
Outstanding Member
- Joined
- Mar 5, 2009
- Messages
- 58,243
- Solutions
- 1
- Reaction score
- 16,107
- Points
- 9,934
I went with an HDMI 2.0b audio extractor. That turned out to be the best option for me.
Amazon.com: Orei 4K 60Hz 18G HDMI 2.0 Audio Converter Extractor ARC Support - SPDIF + 3.5mm Output - HDCP 2.2 - Dolby Digital/DTS Passthrough CEC, HDR, Dolby Vision, HDR10 Support (HDA-925): Electronics
Buy Orei 4K 60Hz 18G HDMI 2.0 Audio Converter Extractor ARC Support - SPDIF + 3.5mm Output - HDCP 2.2 - Dolby Digital/DTS Passthrough CEC, HDR, Dolby Vision, HDR10 Support (HDA-925): Electronics - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Works great.
Siuch an extractor would limit you to audio formats that can be conveyed via S/PDIF optical. S/PDIF optical cannot cnvey HD formats such as DTS-HD Master Audio or Dolby TrueHD. It also wouldn't be able to handle Dolby Digital Plus or more than just 2 channels of PCM audio.
If wanting to split the HDMI output and still have access to HD formats that you'd need something a bit more specialised. THe HDFury AVR Key for example has the ability to split the HDMI signal into 2. allowing you to send the HDR UHD video directly to a comliant display while sending the audio to an older AV receiver via HDMI. THis arrangement will allow you to convey HDR 4K UHD video to a TV while simultaneously sending HD formatted audio to an AV receiver via the second HDMI output:
HDF 0100 - 4K Ultra AVRkey
Features1x HDMI-A (18Gbps) Input || 2x HDMI-A Output (1x 18Gbps AV, 1x 720p / 1080p Audio), 1x USB-InputSuitable for all setups - Loops through any HDMI, HDCP and HDR signal from source to displ [...]
www.reichelt.com
AVR Key 18Gbps | HDFury.com | Connect and Fix everything in HDMI
Our AVR-Key UHD/HDR/DV passthru + 720p/1080p Full HDMI Audio Kit includes: AVR-Key Processor Choice of power supply USB > mini USB cable Extract Full HDMI audio from any signal ! Plug any AVR in any HDMI setup and Play full HDMI audio sound ! Support all audio and video formats in existence...
www.hdfury.com
— As an Amazon Associate, AVForums earns from qualifying purchases —
