hisserbee
I've had my Yamaha RX-V677 for a couple years, and at my previous apartment where I was using the simplest router from the ISP, I was able to connect the receiver to wifi and use the internet radio services. I have since moved and gotten a new router, as well as had the receiver serviced under warranty for a blown HDMI out unit.
Since moving I have not been able to get the receiver to connect to wifi in any way. Access point scan immediately gives me "Can't find any access points", manual setup says the same thing but takes longer to do so, and if I try to share my settings from iOS it just says it failed to share without further information. I have no idea if the issue is with my router configuration or if the receiver's wireless antenna is just broken. Does anyone have any experience with this sort of failure or know how to narrow it down?
