G
georgeC
hello,
First post, first question
Can someone tell me if any of this receivers (yamaha rx-v659 / sony strda1200es) does bass management with analog sources?
I mean, if I play a music cd, the receiver should send music to my front speakers and subwoofer, and if I set crossover (to 80hz for instance), and my fronts are set to "small" it should send ONLY 80hz and higher signals to my speakers and lower ones to my subwoofer. Is this it?
This is supposed to be the behaviour of any receiver when you play a dvd movie, but it's not always so with analog sources. For instance Cambridge 540r doesn't make it
Thanks in advance
Thanks in advance
