Yamaha RX-V650 - overkill for this setup ?
Discussion in 'AV Receivers & Amplifiers' started by Matta_Z, Oct 18, 2004.
Tags:
  1. Matta_Z
    Matta_Z
    Sep 11, 2004
    9
    Greetings !
    I was planning to buy Yamaha RX-V650 receiver. However, I doubt that I will have 7.1 speakers in the near future (due to limits of the room).
    Now I'm thinking about Yamaha RX-V550 (6.1). What are the differences between these 2 models ? Is there any feature that 550 doesn't have compared to 650 ?
    Furthermore, is either of these 2 models overkill for JMLab Sib & Cub2 5.1 speakers ?
    Should I look for some other speakers ?
    Thank you in advance !
  2. CosmicOne
    CosmicOne
    if u have the money get the RXV650 coz it has another benifits over the 550 not just the 7.1channels:
    1-It has more weight which means a better Power Supply than the RXV350/450/550.
    2-It has Pure Direct Mode for stereo which is very very good & effective & not found on the 550.
    3-the 7.1 channels will be future proof & u can use the presence channels instead of the two surround back channels.
