Yamaha RX-V630 & wireless headphones
Discussion in 'AV Receivers & Amplifiers' started by Wabos, Jun 12, 2009.
Tags:
  1. Wabos
    Wabos
    Jun 12, 2009
    2
    I am having trouble hooking up my wireless headphones in a way that allows me to get sound on my speakers AND the headphones.
    My ‘devices’ are
    1. DVD
    Connected via optical cable port 2 (DVD)
    2. DirecTV receiver (HR23/700)
    Connected to TV via component cable, back to D-TV/Cable via RCA cable
    3. Roku (Streaming video player)
    Connected via optical cable port 3 (MD/CD-R)
    At this point everything works fine, I can select the appropriate Input source and all is good.
    I have a set of Acoustic Research headphones (Model AW-791) and they have 3 inputs.
    1 = RCA
    2 = Toslink (optical)
    3 = Digital
    My ‘logic’ says that I should be able to use my headphones as an extension; ie whatever input source I am using should also output sound to a ‘port/output’ that I can hook up to --- without impacting my normal speakers but no amount of cable switching has worked.
    I have the owners manual but I guess I am dumber than a stump with this stuff (my grandson normally does it for us <g>) so any guidance would be appreciated.
  2. Wabos
    Wabos
    Jun 12, 2009
    2
    As it turns out, Yamaha actually has 'live' support!
    This receiver only has an analog output for my purposes so it won't work for my purposes as a number of my 'devices' use digital cables for output.
    Wabos
