Yamaha rx-v573 sound delay problem
Discussion in 'AV Receivers & Amplifiers' started by jovanja, Feb 11, 2014.
Tags:
  1. jovanja
    jovanja
    Feb 11, 2014
    3
    Hi all,
    i would like to ask for a help how to fix an issue with my yamaha receiver,
    i have the following connections,
    music coming from a PC to a focusrite saffire sound card,
    from the focusrite saffire the connection goes to allen & heath xone 42 dj mixer,
    from the allen & heath xone 42 mixer i have 3 outputs going to
    1 active studio monitors,
    2 active pa speakers
    3 yamaha rx-v573 av receiver (using 2 front speakers and sub)
    i use these 3 sets of speakers separately for their purpose,
    but sometimes i like to put them all 3 at the same time,
    at first i didnt had any issues,
    all three sets were going in sync when music played,
    now i have the first 1,2 in sync and the 3 yamaha receiver slightly off sync
    the yamaha is off sync with the 1 and 2 speakers if i use the 2ch stereo setup in music mode (and in any mode with the sub on)
    only if i engage the receiver in direct mode the sound is back in sync with the 1 and 2 , but than i dont have the sub
    i havent changed anything in the setup so cannot really tell what made this difference
    i tried connecting from the focusrite saffire sound card straight to the receiver but the delay is still there and it's out of sync with speakers 1 and 2,
    so hope for some help how to bring the receiver back in sync with the other speakers when i have the sub on the speaker on,
    thanx in advance
    jovanja
  2. jovanja
    jovanja
    Feb 11, 2014
    3
    anyone?
  3. jovanja
    jovanja
    Feb 11, 2014
    3
    hi,
    i cannot be the only one using this type of connections (dj mixer with three outputs to three sets of speakers in one room)
    so any input would be welcome,
    because i have the sound on the receiver out of sync with the sound of the other two pairs (noted 1 and 2 ) in any mode selected (2ch stereo, straight....) and it's in sync only when i select direct mode it makes me think that there is some processing inside the receiver that makes this small lag to be out of sync,
    what can i select on the yamaha to have a simple 2.1 setup for music sound?
    is it recommended to do a reset of the amplifier?
    (because before i didn't had any lag between the receiver and the other two pairs of speakers- everything was in sync)
    well hope for some tips,
    thanks
