Rizvan
Hi all,
really can`t make my mind up which one will be the best for my setup.
£238 Yamaha RX-V565 (will fit into current storage as per my current amp 4cm gap)
£279 Marantz NR1501 (easily fit into current storage with plenty of room)
£299 Denon AVR1910 (will have to buy a new a/v storage unit only 1cm gap)
B&W 603 S3 fronts
B&W 601 S3 rear surrounds
B&W DS6 di-pole back surrounds
B&W CC6 S3 center
B&W AS500 sub
PlayStation3 outputting into Neet HDMI splitter feeding the PH9 plasma and HD20 projector.
Which one would you get people and why?
Also looking at the Denon manual I can see that when your viewing standard 5.1 or HD 5.1 you can set the amp to enable the back surrounds to feed off the rear L&R surrounds, is this the case?
Thank you in advance.
Riz
B&W 603 S3 fronts
B&W CC6 S3 center
B&W AS500 sub
Riz
