Just got this set up on Tuesday but I'm having a couple of problems with it.
I have it outputting to my Samsung LE40B550 TV and inputs from a Cambridge Audio DVD86 DVD player and Xbox 360 (HDMI).
When I'm playing music through the DVD player on HDMI input, the sound cuts out and stutters when I switch the TV on. Same thing happens with the 360 but the receiver clicks 4-5 times (like the click when you switch it on). If I am playing the music through the analogue (RCA connections) then it's fine. I have tried another HDMI input on the TV and get the same problem. I have also tried using the 'direct' feature (which apparantly uses less circuitry) and it does the same.
I also understand that this receiver can't assign different audio inputs to different video inputs, which may be a problem when I get a HTPC (unless I connect the HTPC directly to the TV). I have also heard that people have had problems using Wiis for the same sort of reasons.
Any suggestions?
Any suggestions?
