dante01
Thanks for your settings I will give them a try.
But for my initial question, is that really intended to create an echo chamber with the movie and gaming profiles?
I mean, I get it for the music presets it sounds like the music halls.
But I have never been in an cinema with that much echo.
The echo is simply related to the delay. You can ordinarilly reduce it or even het rid of it by reducing the delay associated with the surrounds and this will result in the effect dimishing in assocuation with elements such as the dialogue.
It isn't technically incorrect though and is actually what you would hear in a room the size as the one you are attempting tocreate within the space you have your setup within. It is basically recreating the kind of effect you'd experience within a stadium or indeed a movie theatre.
Playing about with the room sizes and the delay settings can and will allow you to configure the programs more to your liking. I'd not suggest using the Music options and sitting pretending you are in a churd or visiting a beer leller though. Those settings are a bit OTT and gimmicky.
