SevenLord
Hi, I’m trying to connect my home theater receiver (Yamaha RX-V4A) to my TV (LG 75NANO80VPA - WebOS 6.0) but there is no sound.
Connected HDMI 2.0 cable (image) from the TV eARC/ARC HDMI port (image) to the HDMI out port on Yamaha (image).
The Yamaha is set to work with ARC (image).
The TV is set to work on ARC (image), eARC disabled (image).
The Yamaha is set to work on TV, which to my understanding is the mode to get input audio from the TV (image).
But playing anything on the TV doesn’t make sound from the Yamaha’s speakers.
Am I missing any settings? Is it possible to determine if the problem is with the TV or with the receiver? (the speakers obviously work from my test below).
Note:
Note:
- The speakers setup is going to be 4.1 (4 speakers, 1 subwoofer).
- At this time only 1 speaker connected to the Front Right, if it works I'll connect the rest, but first I want to know if it's working.
- Also tested using the MusicCast Controller, it played music from my phone and the speaker worked fine.
- Tested with both “PCM” and “Pass through”, didn’t work either way.
- I didn’t touch any of the Zone settings, it's going to work in a single room.
- The HDMI cable was also tested between my laptop and my TV and it worked fine.
- I know for eARC I need HDMI 2.1+ but for now this is what I got.
- I don’t own another TV that supports ARC, so I couldn't test on other TVs.
