Yamaha RX-V496RDS with no pre output
Discussion in 'AV Receivers & Amplifiers' started by chapar, Apr 8, 2005.
Tags:
  1. chapar
    chapar
    I want to connect my Yamaha RX-V496 RDS AV Reciever to my Arcam A85 Integrated Stereo Amp. Therefore I want to have one system for Stereo & Home Theatre.
    However, Yamaha V496 does not have a pre output, which make this integration not possible.
    Does anyone has an alternative soluiton for that? The first thing comes to my mind is to use the speaker outputs of Yamaha and one available input in Arcam. Not sure if it works. And also not sure tha power output differences between two amps would create problems. (Yamaha 100 watt/ 8 ohms, Arcam 85 watts/8 ohms)
    I would be grateful if someone can help me.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,883
    Derby
    +935
    Hi Chaper, welcome to the Forums. To get an answer on this you should really post this question in the Integrated Amplifiers & Receivers section.
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,392
    In a secret location with Jennifer Lawrence
    +7,237
    Yes, welcome to the forums chapar.
    We have dedicated forums for each type of subject/topic etc. I have moved this to the AV receivers forum where it is better suited.
    Greg
