Yamaha RX-V450 to Screen
Discussion in 'AV Receivers & Amplifiers' started by fanTom, Jun 13, 2005.
Tags:
  1. fanTom
    fanTom
    Jun 1, 2005
    32
    Hi, I'm still new to all this but I'm looking at getting a Yamaha RXV450 but I'm not sure how many cables I need to go from the amp to the screen. (I say screen because I currently have a TV but am looking at getting a Plasma in the next month - one thing at a time!)
    If I connect my sky box to the amp with a scart to composite (and stereo audio) and my dvd player using component, do I have to take composite and component out of the amp to the screen or can I just take a single connection eg component and are the other signals converted?
    May be a simple question, but I've downloaded the Yamaha manual and I'm still not sure.. :confused:
    cheers
  2. Van300
    Van300
    Jan 3, 2005
    182
    Derby, UK
    +11
    I have the 757 which is connected to the TV via component only and would presume the 450 to work in the same manner.
  3. fanTom
    fanTom
    Jun 1, 2005
    32
    Hmm. had a quick look at the 757 and it mentions "Video up conversion to component for all video inputs" - I don't think the 450 has this.....
  4. Van300
    Van300
    Jan 3, 2005
    182
    Derby, UK
    +11
    The 450 does not but the tv will upconvert it I think, ie the 450 will send SD via component to the tv and the tv will upconvert. Presumably component can be used to send SD signal as well as HD etc.
  5. fanTom
    fanTom
    Jun 1, 2005
    32
    Thanks - I'll keep investigating.
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    you have had pretty vague answers so far, the 450 does not upconvert, so yes you will have to run a composite as well as component.
  7. fanTom
    fanTom
    Jun 1, 2005
    32
    Thanks chedmaster, so the 450 simply switches between the connected devices within the connection type and between types but you need all types of output connected to the screen :eek: SO I would need both composite and component cables to the screen. :smashin:
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    presactly :)
  9. Passingbat
    Passingbat
    Feb 20, 2003
    7,564
    UK
    +1,335
  10. fanTom
    fanTom
    Jun 1, 2005
    32
    Nice idea about delaying the purchase. I'll need to think about it. It's double the price and then there's the speakers to go with it (I fancy the canton movie set on offer here).
    I only have sky, dvd, video, linksys media hub to connect, although the dvd does have component - Just not sure if I'd appreciate the extra quality / capabilities, and I hope the extra cables would be cheaper than £140 :D
    Why are decisions so difficult :suicide:
