Yamaha RX-V450 Size
Discussion in 'AV Receivers & Amplifiers' started by Black20VT, Jun 16, 2005.
Tags:
  1. Black20VT
    Black20VT
    May 4, 2005
    369
    +13
    Hi all,
    I'm tempted with the current Superfi deal on the 450 to replace our Denon AVR483/1403, but on looking at the dimensions, things might be a bit too tight.
    The depth is 416mm, but does this include the protruding speaker terminals, or do I need to allow extra for this?
    Can anyone with the 450 quickly measure it up for me and confirm the depth complete with speaker terminals?
    I don't want to order it and then find it doesn't fit.
    Thanks in advance! :thumbsup:
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    I dont have a 450 to hand but measured the RX-V457 which has the same chassis, and the depth including the binding posts is approx 400mm. This is measured from front of unit, but not from front of volume control, which as you know protrudes from the front.
