Yamaha RX-V450 from Superfi
Discussion in 'AV Receivers & Amplifiers' started by ArsoN, Jun 28, 2005.
Tags:
  1. ArsoN
    ArsoN
    Well, it's getting extremely close to me laying out the cash on an AV receiver. I've found the RX-V450 on Superfi for £130, any opinions? It looks to be a hell of alot of bang for your buck.
  2. alphabet
    alphabet
    On paper the RX-V450 does sounds impressive and because of that I bought one in January. However everything is not as impressive as on paper. Yes it will work nicely in a small room with efficient speakers in movie mode, but in stereo(music) mode its a dog.
    It is claimed to deliver 85w RMS into all channels, but it is more like 45-50w RMS.
    On the other hand in that price range I can't think of anything better either!
    Bottom line, if you plan to use it in a small room, mostly in HT mode and pair it with speakers such as Kefs, it will do the trick.
  3. ArsoN
    ArsoN
    It will be used in a small room, and paired with a Canton CD1 set. It'll pretty much only be used for 5.1 cinema, I have a seperate amp + speakers for music.
    Thanks for the help. :smashin:
  4. empirix
    empirix
    Apr 19, 2005
    55
    9
    I am also tempted by the Superfi offer ... I have 5 x Anthony Gallo Micros ... is this amp a good match ?
    Any other recommendations ?
  5. rdevarajan
    rdevarajan
    Jul 15, 2005
    509
    Wembley
    +22
    i got yamaha rxv 450 and am completely satisfied with it... for a small room it is more than sufficient.
  6. systemsdead
    systemsdead
    Jan 19, 2005
    7,990
    grimsby,canada
    +1,664
    does anbody know if the rxv 357 is a newer model than the rxv 450 only diff i can see is 5.1 and 6.1 i will only be using 5.1 layout so should i go for the 357
  7. spickee
    spickee
    May 8, 2001
    239
    MK
    +5
    No audio delay either, this is the same quandry I'm having.
  8. rdevarajan
    rdevarajan
    Jul 15, 2005
    509
    Wembley
    +22
    depends on how deep u guys are into music... 6.1 is indeed a shade beter than 5.1... if that helps... i have a yamaha 450..i did listen to 357 and did not find any great difference... will depend on the speakers too
  9. spickee
    spickee
    May 8, 2001
    239
    MK
    +5
    Choice just got harder Superfi are selling the 457 for £149 for the titanium model.
