Yamaha RX-V385 YPAO mic placement without stand or tripod
Mooky78
I just bought a used Yamaha RX-V385 receiver online as an upgrade to my older Yamaha receiver. Ordered the YPAO mic from someone else, since the seller didn't have one with the receiver. I don't have a mic stand or tripod for the mic and wanted to know what else I could use to place it ear level behind the couch. I'm thinking maybe to just manually set the speakers up with the same settings my receiver I have now has. Still wanted to try the YPAO out. Never used it before. Thanks in advance for the help.
Dolus
dante01
You'd be best advised to locate the mic where you'd ordinarilly be sat while using the setup as opposed to placing it behind and away from where your location will be. Many use a stand that accomodate a mic boom and this makes it easier to locate the mic where you'd be sat and at your seated head height.
Amazon product
This little gizmo is also quite handy, but not cheap:
Amazon product
Mooky78
Thanks. I'll check out the US site. I thought if I used the tripod just behind the couch, mic should be at ear level where I sit. Maybe I can get it to stand on the couch?? Even thought about setting it up right in front of it, but not sure.
Mooky78
Thanks. I'll have to check out the US site. I thought if I used the tripod just behind the couch, mic should be at ear level where I sit. Maybe I can get it to stand on the couch?? Even thought about setting it up in front of it, but not sure. Can get the tripod cheap.
dante01
Buy a mic stand with a boom as opposed to using a camera stand. The boom will make it a lot easier to locate the mic where your head would be while sat.
See here:
https://www.avforums.com/threads/audyssey-boom-mic-stand-under-£10.2173823/
Mooky78
That's UK linkage. I'll hafta check out Amazon US. Not sure if I want to spend that much. Tripod is cheaper
dante01
The adaptor isn't strictly speaking a necessity. The mic stand and boom are the main comcern and you'd be able to pick these up quite cheaply regardless where you are shopping from.
The boom arm element makes it far easier to locate the mic where your head would be while seated.
Mooky78
How about this one? How do you attach the mic without the extra attachment and just the mic clip?
dante01
You can basically tape it to the boom arm it you've nor the adaptor or a spring clip type mic holder.
Mooky78
Ok. This is the mic I'm getting. How would I tape it to stand?
dante01
Adjust the mic holder so that you can tape it to it. I'd suggest using two pieces of tape, one to either side of the mic so as not to cover the actual mic itself. Isuggest using the mic holder because this would allow you to orientate the mic and adjust the angle it is at.
Spring clip holders are better because you can hold the mic with them without any need for tape.
Mooky78
Thanks. Might hafta just try the tape method if I go mic stand route.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
