Yamaha RX-V3800 problem (connecting pc via hdmi)
Discussion in 'AV Receivers & Amplifiers' started by friedman30, Jun 10, 2009.
Tags:
  1. friedman30
    friedman30
    I am trying to connect a PC (Radeon 3870 with dvi to hdmi connector and a hdmi to hdmi cable) to my new Yamaha RX-V3800 receiver.
    The PC was connected to the TV set directly until now. (all worked fine)
    I have changed the setting in the receiver so that the input would be the hdmi.
    When I turn on the receiver I get to see the PC for a few seconds before the receiver turns on it's screen-saver (wallpaper?) and I can't get it to show the PC again.
    I have tried a new driver for the computer's graphic-card, tried setting the wallpaper off, nothing helps. :confused:
    Any idea on how to solve this? ? ?
    :confused: :confused: :confused:
    Thanks!
    Dror
