I purchased a used Yamaha RX-V377 (HTR-3067) receiver and I hooked it up to my LG CX with an HDMI cable. I currently only have 2 speaker setup.
I have the TV set to passthrough, the other option is PCM. When I'm watching shows on Netflix, the audio usually defaults to 5.1 setup by Netflix and the receiver decoder info is showing Dolby Digital+ signal. I can choose a wide array of different sound modes on the receiver, but I figured that STRAIGHT is my best option, but now I'm not so sure.
If I have STRAIGHT mode selected, is the receiver downmixing the 5.1 signal to 2 channel stereo? Or is it sending through a 5.1 signal, even though I only have 2 speakers?
If the latter is true, then does that mean I'm missing certain audio, which I could only hear if I had a 5.1 system? If that is the case, then should I change the sound to stereo in Netflix menu or choose 2ch stereo music mode (downmixing) on the receiver or set audio mode to PCM on the TV? If I have the audio mode set to PCM on the TV, it seems it disables any kind of surround mode signal, since in Netflix I can't choose 5.1 anymore, it automatically defaults to stereo mode.
