hello i need a bit of advice i am looking to by the yamaha rx-v371 to replace my current panasonic sc-pt470 home theater system and would like to know if my panasonic speakers are ok to hook up to the yamaha the speck on the speakers is as follows
front and surround
1 way 1 speaker system (base reflex )
3 ohm impedance
6.5 cm cone
125w*8 input power (max )
79db/w (1.0m) output pressure
100Hz to 25KHz (-16db)
120Hz to 22KHz (10db)
center speaker
2 way 2speakear system (base reflex )
6 ohm impedance
woofer 6.5cm
full range 6.5cm
250w*8 (max) input power
81db/w (1.0m) output pressure
82Hz to25KHz (-16db)
99Hz to 22KHz (-10db)
sub woofer
1 way 1 speaker system (base reflex)
6 ohm impedance
16cm cone
250w (max) input power
31Hz to 220Hz (-16db)
37Hz to 180Hz (-10db)
any advice most appreciated
front and surround
3 ohm impedance
6.5 cm cone
center speaker
6 ohm impedance
woofer 6.5cm
full range 6.5cm
sub woofer
6 ohm impedance
16cm cone
