yamaha rx-v359 bana pot help!!!
S
sunnyb4u
hi guys i havent been on these forums for ages but ill give my question a shot
erm i recently did a modification to my panana plug connection on the back of this sub as the caps didnt accespt 4mm bana plugs and i cut the plastic in the middle out with a knife very easy to do erm i just have a slight problem now
erm i can now insert the 4mm banaa plugs into the connectors but they seem to go deep in with a audible click to confirm its in but i dont hear sound until i move and hold the connectors
i think the sockets are too big for 4mm connectors ive tried the long ones and the small wide fitting banana plugs all from maplins.co.uk but i am stuck as i dont want to hold the connections to get sound even though the posts work if i thread the speaker cable into the back of the connectors by untwisting and feeding cable throiugh then tightening up
somebody please help as it aint broken since i get sound but i have to lean them to an angle to get sound and it sounds clearer than wire strands round the connector please help as i am pulin me hair out thanxs and ps the plastic around the connecotr is off so you can see the bana posts connectors clearly :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
S
sunnyb4u
sorry the title was supposted to be banana post help thanxs
